																			 MAXPOWER
						Post
								by MAXPOWER »
			Hello--- since my search for a crank handle has  not bore any fruit does anyone have one they can measure for me so i can have one made?
thanks in advance!
																			 Miles
						Post
								by Miles »
			Hope this helps...
Can anyone confirm this is original fordson issue?
- Grumpy
						Post
								by Brian »
			Yes.
																			 Kjetil
						Post
								by Kjetil »
			Something is missing.
You need a peace of steel going through the hole in the front.
Mine is different, maybe not original.
I will se if I rember to take a picture.
Kjetil
- Grumpy
						Post
								by Brian »
			The shaft is usually part of the tractor not the handle on Majors.
																			 MAXPOWER
						Post
								by MAXPOWER »
			Miles thanks  can you please verify the square opening? i thought it was 3/4 inch  looks bigger in your pictures?
