F in L's early Super has just severed the left wheel. Any pointers as to removal of said shaft would be appreciated. Is then anything to be careful with when removing the top cover (and replacing).
Regards Peter
Broken rear drive shaft
No problems on getting the top cover off. Don't forget the two nuts, one either side, up under the lift arms. Just do not set it down on the control valve with the metal trumpet on. When off, its best to stand it on the lift arms/top link to avoid any chance of damage.
Crane would be best if possible. I have a ring that bolts on to the seat bolts from my service days.
Once you are in, its just a large castellated nut and you will need to lift the "strakes" out of the groove where the seal fits. The shaft should draw straight out then.
Must be the year for half shaft failure! I had one go on Harriet whilst I was loading muck a few days ago.
essex pete
