  Miscellaneous topics
  Photos
Author Topic:   Photos
posted June 26, 2005 11:32     Click Here to See the Profile for Emiel   Click Here to Email Emiel     Edit/Delete Message   Reply w/Quote
Last week I was in Dongen (netherlands) were a tractor show was organised. On this very nice event this year the main theme was Ford and Fordson.
I made a lot of photo's and these I want to show you.
[This message has been edited by Emiel (edited July 11, 2005).]
posted June 26, 2005 11:44     Click Here to See the Profile for Emiel   Click Here to Email Emiel     Edit/Delete Message   Reply w/Quote
The first pictures show a differential locking on a new/power major tractor fitted, a non Ford item which uses another top lift casting.
We also see a green straight petrol major frome some army, equiped with a lpg installation. This has NOT been a TVO major.
And we see a Hendre road leveller based on a Ford 6y 5000. Hendre is a company in my region who build very special machines. They are said to have build loading equipment based on e27n in the 40ties and fifties.
And as last a N with rotaped conversion, quite rare, here in Holland at least.
I forgot to take some good pictures of the KFD narrow major with howard box fitted between the gearbox and rear axle.
posted July 11, 2005 09:56     Click Here to See the Profile for Emiel   Click Here to Email Emiel     Edit/Delete Message   Reply w/Quote
new try, with the pictures,
try this link: http://www.mijnalbum.nl/Album=6NEI3RXC
Oscar
posted July 11, 2005 13:09     Click Here to See the Profile for Oscar     Edit/Delete Message   Reply w/Quote
What is this pedal for? And the lever?
[This message has been edited by Oscar (edited July 11, 2005).]
posted July 11, 2005 13:44     Click Here to See the Profile for Emiel   Click Here to Email Emiel     Edit/Delete Message   Reply w/Quote
I think that pedal is a aftermarket non Ford conversion, so a differential lock can be used. I have some more pictures of that item, which was also fitted to the green Major.
The little "T" shaped lever is the brake pedal locking device, fitted to all agricultural E1A Majors, for as far as I know.
Maybe Brian knows more about the diff lock item?
posted July 11, 2005 18:09     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
Never seen anything like it. There have been major changes in the top cover and, from its position I would love to see how the back end has been modified as the lever etc. is high above the dif. I would think that it is a "dealer" mod as I know of no Ford mod. It could also be an experimental one that was kept quiet (as usual).
posted July 11, 2005 18:58     Click Here to See the Profile for Emiel   Click Here to Email Emiel     Edit/Delete Message   Reply w/Quote
From this item some more details are pictured. The green one was also fitted with this option. The complete lift casting was replaced with a NON FORD item and al the Ford parts for the hydraulics and the linkage were fitted to this casting.
Oscar
posted July 11, 2005 19:31     Click Here to See the Profile for Oscar     Edit/Delete Message   Reply w/Quote
Another shot:
Oscar
posted July 11, 2005 19:32     Click Here to See the Profile for Oscar     Edit/Delete Message   Reply w/Quote
posted July 12, 2005 10:28     Click Here to See the Profile for Emiel   Click Here to Email Emiel     Edit/Delete Message   Reply w/Quote
And another one, with text:
Henk
posted October 07, 2006 21:26     Click Here to See the Profile for Henk   Click Here to Email Henk     Edit/Delete Message   Reply w/Quote
Hello,
Although the pictures have all ready been removed, I write some interesting things about this subject. Today I visit a friend who knows a lot about Fordson Major. He is building 3 of them at this moment. One of them has the diff. lock you describe Emiel. He told me, because Fordson was not ready with there one diff. lock that they want to place on the Power Major, they let them make by Selene. Only about 400 of them were produced. It works simple. The axle goes over the big gear wheels in the rear end and trough shifting a few gears over them they lock. So according to this story, it's not after market.
Regards Henk
[This message has been edited by Henk (edited October 07, 2006).]
posted October 15, 2006 18:07     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
Barry in Aus. sent me a leaflet on the dif. lock for the E27N and the E1A Majors that was manufactured here in England by a company called Darlington Engineering of Gateshead on Tyne.
There are a couple of splined hubs that bolt on to the bull gears and then have a sliding coupler between them. Looks very simple.
There is a note on the leaflet that it is pattented by "Salzmann".
posted October 16, 2006 09:17     Click Here to See the Profile for Emiel   Click Here to Email Emiel     Edit/Delete Message   Reply w/Quote
I'll find out whether I do still have the pictures and post them again in a new topic.
Henk
posted October 16, 2006 10:43     Click Here to See the Profile for Henk   Click Here to Email Henk     Edit/Delete Message   Reply w/Quote
Hello,
I will try to get some photo's of it.
Henk
Henk
posted October 18, 2006 20:10     Click Here to See the Profile for Henk   Click Here to Email Henk     Edit/Delete Message   Reply w/Quote
Hello,
Here is a photo from the top side.
When the lever is pushed down, it turns a hook about 90 degrees. This will move a splined bush with a gear and shift it over one end gear. The other is always engage.
At two sides there is cast the word Brevetta. This is Italian for diploma.
Regards Henk
Henk
posted October 19, 2006 18:21     Click Here to See the Profile for Henk   Click Here to Email Henk     Edit/Delete Message   Reply w/Quote
Hello,
This is the Darlington Engineering diff lock leaflet from Brian
Thanks Brian.
Regards Henk
Henk
posted November 26, 2006 16:08     Click Here to See the Profile for Henk   Click Here to Email Henk     Edit/Delete Message   Reply w/Quote
Hello,
Yesterday I visit a Guy that had parts for sale. He had several New, Power and Super Majors. Two of them had this differential lock on them.
He also owned a 54 New Major. He painted it with a brush. It was as far as I could see completely original. All the parts that normally are worn out an replaced when a tractor is in use over such a long time were still in place. Such as pins an stabilisation parts from the lift and drawbar. It only leaked oil at the steering house by the oil sealing and the endplate. On one cylinder he had to place a new bush. I don’t think the tractor had many working hours. I hope to see him again and take pictures of it.
Regards Henk
Pascal
posted November 27, 2006 13:21     Click Here to See the Profile for Pascal   Click Here to Email Pascal     Edit/Delete Message   Reply w/Quote
Hi Henk,
Where you able to buy the missing parts for your lift? I hope so!
Best regards,
Pascal
Henk
posted November 27, 2006 20:54     Click Here to See the Profile for Henk   Click Here to Email Henk     Edit/Delete Message   Reply w/Quote
Hello Pascal,
The guy advertised with the New Major rim disc for the rear wheels and they were not expensive and without rims and tires. There were two pare. He also had a lot of parts for sale, so I thought maybe some lift parts. The rim disc where very worn and rusty, so I didn’t buy them after all. He needed the lift parts himself, so no luck.
Last week I finished the repair of the lift adjustment part. Now I only have to make new pins and repair the lower lift arms. After that one halve of the stabilisation chain needs to be done, but maybe I can find the right part for that. So I hope to be done in about two weeks.
Regards Henk.
[This message has been edited by Henk (edited November 27, 2006).]
Pascal
posted November 28, 2006 12:00     Click Here to See the Profile for Pascal   Click Here to Email Pascal     Edit/Delete Message   Reply w/Quote
Hello Henk,
Too bad the rims were too rusty and worn. Bad luck about the lift parts.
It's really nice to have a Major: they always keep you busy! But that's of course part of the hobby.
Yesterday evening, I removed the (old) paint the last rear-rim. I only need to remove the paint of both the front wheels and than the painter can do his job. I am very curious to the result!
I'll keep you posted.
Best regards,
Pascal
posted November 28, 2006 16:24     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
Henk,
I have a couple of Major rear wheel discs. They are rusty but in good condition. Any use?
Henk
posted November 28, 2006 23:11     Click Here to See the Profile for Henk   Click Here to Email Henk     Edit/Delete Message   Reply w/Quote
Hello Brian,
Thanks for the offer, but it’s a bit difficult to get them over here. I have the rim disc model from the Power and Super, and they look great. But I want to have the ones that belongs on the 57 model. Maybe something to remember when we have a get-together again.
Pascal, I think you have eaten enough rust and dust the last weeks. I’m sure they are going to look great on your Super.
Regards Henk.
