  Miscellaneous topics
  Plough setting up
Author Topic:   Plough setting up
jambug123
posted November 03, 2006 15:39     Click Here to See the Profile for jambug123   Click Here to Email jambug123     Edit/Delete Message   Reply w/Quote
hi all since my grandad is ill in hospital i need some advice. im ploughing using my dexta and a ferguson 2 furrow plough which has a off set frame work. the question is about front wheel tracking. should the front wheels be set in on the narrowest setting with 400-19 wheels or should they be set further out?.
thanks for any help
james
posted November 03, 2006 16:16     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
James,
Two ways of doing this:
1. Line up the inside of the front wheels with the inside of the rear wheels.
2. Line up the centre of the front wheels with the centre of the rear wheels.
I use method 2 as, in Norfolk we have a lot of flints and if the front tyre runs along the furrow wall it gets cut.
Rear wheel setting is important to allow the plough to run in the correct place easily although you do have sideways adjustment on the plough cross shaft.
If you measure the plough point to point width between the bodies, you should have the same distance between the front point and the tyre, give or take 1/2" when the plough is on the ground.
jambug123
posted November 03, 2006 17:00     Click Here to See the Profile for jambug123   Click Here to Email jambug123     Edit/Delete Message   Reply w/Quote
thanks brian, one other question how should the plough sit on the back of the tractor should it be level on both plains? since my grandad usually sets it up.
cheers
james
posted November 03, 2006 18:12     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
Level in both planes when the tractor is in the furrow. To check the level when going forwards, stop with the brakes and apply the hand brake. It may sound strange when you have the plough in the ground but if you stop normally the tractor eases back slightly and the plough will rise slightly at the front. So it will not be as it is in work.
Also check the open furrow. The bottom should be at right angles to the furrow wall and you should be able to see a clear mark from the heel iron where the furrow floor meets the furrow wall.
jambug123
posted November 03, 2006 19:09     Click Here to See the Profile for jambug123   Click Here to Email jambug123     Edit/Delete Message   Reply w/Quote
thanks again brian, i will get and do some ploughing tomorrow and hopefully make my grandad happy.
cheers
james
jambug123
posted November 05, 2006 19:24     Click Here to See the Profile for jambug123   Click Here to Email jambug123     Edit/Delete Message   Reply w/Quote
what would you recomend as the best wheel track setting for ploughing with my dexta?
cheers
james
posted November 06, 2006 08:39     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
James,
I would suspect 56" but it is not really too important as long as your distance for our front furrow is the same as between your first and second furrows.
I have all my tractors set at 60" because this is the setting for planting and working the spuds. I plough with a TS82 set at 14" furrows and a Ransomes digger and a PM both set at 12" furrows.
jambug123
posted November 06, 2006 16:37     Click Here to See the Profile for jambug123   Click Here to Email jambug123     Edit/Delete Message   Reply w/Quote
thanks brian, its currently running at 48''. so ill adjust the plough on the cross shaft and see how i get on.
cheers
james
jambug123
posted November 08, 2006 19:28     Click Here to See the Profile for jambug123   Click Here to Email jambug123     Edit/Delete Message   Reply w/Quote
thanks for your help brian, my dexta and ferguson 2 furrow plough is ploughing superb, both furrows are even and the open furrow is at 90 degrees.
cheers
james
posted November 09, 2006 08:27     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
Glad to have helped James, next year, the world ploughing championships?
jambug123
posted November 09, 2006 08:33     Click Here to See the Profile for jambug123   Click Here to Email jambug123     Edit/Delete Message   Reply w/Quote
yeah have thought about it,it would be nice to show them red /grey horrors up.
