  Parts for Super Major
Author Topic:   Parts for Super Major
beamo5
posted August 01, 2005 17:05     Click Here to See the Profile for beamo5   Click Here to Email beamo5     Edit/Delete Message   Reply w/Quote
First time on this site, been reading your posts and find it interesting. I know where there is a Super Major tore down with power steering.
Andy K
posted August 03, 2005 22:28     Click Here to See the Profile for Andy K   Click Here to Email Andy K     Edit/Delete Message   Reply w/Quote
I might be interested in the power steering for my Major. Do you know if the steering system is complete? I am not sure of everything I would need for the conversion.
beamo5
posted August 04, 2005 17:00     Click Here to See the Profile for beamo5   Click Here to Email beamo5     Edit/Delete Message   Reply w/Quote
This tractor is complete, it was running until the guy took the head off.
MMyers1
posted August 14, 2005 16:59     Click Here to See the Profile for MMyers1   Click Here to Email MMyers1     Edit/Delete Message   Reply w/Quote
OHHHH....
I might be interested in the power steering, and perhaps other internal bits too! Where is Woodstock in relation to Huntsville? I have relatives in Huntsville, and I was born in Leeds, outside of Birmingham!!
beamo5
posted August 15, 2005 15:30     Click Here to See the Profile for beamo5   Click Here to Email beamo5     Edit/Delete Message   Reply w/Quote
Woodstock is located halfway between Birmingham and Tuscaloosa right off interstate. The town used to be called North Bibb.
MMyers1
posted August 16, 2005 12:56     Click Here to See the Profile for MMyers1   Click Here to Email MMyers1     Edit/Delete Message   Reply w/Quote
Do you know if the power steering mechanisms are still available? If so, contact me at
mmyers1 at swbell dot net
Thanks!!
Bob-O
posted August 23, 2005 06:25     Click Here to See the Profile for Bob-O   Click Here to Email Bob-O     Edit/Delete Message   Reply w/Quote
Beamo, I've been trying to locate a bolt that holds the PTO onto the rearend. There are 4 bolts, I specifically need the top right one, when viewed from beind. It is 6 1/2" long, and has two grooves in it. If you con put me in contact with the part, or owner, I would be MORE than greatfull. I would be happy to call if provided a #. You can E-mail me at BSarrazine@webtv.net Thanks in advance, Bob-O
posted August 23, 2005 09:11     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
Bob,
The reason you are having difficulties with that bolt is because you do not have a standard PTO. You have a raised PTO which was only fitted in certain markets as an extra.
The bolt you describe is actually the shaft on which the selector moves, part No. E23 GE9. This will be very hard to find although some of our Australian friends might be able to help.
The PTO retaining bolts are 1"3/8 x1/2" 13tpi or 1"3/4 x 1/2" 13tpi for the raised PTO, these are common bolts and readily available from bolt stockists.
Bob-O
posted August 24, 2005 05:40     Click Here to See the Profile for Bob-O   Click Here to Email Bob-O     Edit/Delete Message   Reply w/Quote
Originally posted by Brian:
Bob,
Bob-O
posted August 24, 2005 05:42     Click Here to See the Profile for Bob-O   Click Here to Email Bob-O     Edit/Delete Message   Reply w/Quote
Originally posted by Bob-O:
Brian-
Thanks for the info. You are right on the money with the part number. Can you suggest
a sight or email for the boys down under?
Thanks again.
Bob-o
P.s. Your knowledge is over whelming.
