Topic: Open worked Power Major.
Henk True Blue Posts: 502 From: Arnemuiden, The Netherlands Registered: Nov 2004
posted May 27, 2006 22:22
Hello,This morning the OTMMZ museum was opened after a rebuild. I was surprised to see there an open worked Power Major. It is in loan of the locale NH dealer. Also a member of the association. Regards Henk [This message has been edited by Henk (edited May 27, 2006).]
[This message has been edited by Henk (edited May 27, 2006).] IP: Logged |
Mac True Blue Posts: 161 From: Gowen, Michigan. U.S.A. Registered: Jan 2005
posted May 28, 2006 05:06
Hello,Henk Very nice! I wish I could vist this museum I bet they have some real nice displays!!! Hope you are having a good holiday!!Always the Best Mac  [This message has been edited by Mac (edited May 28, 2006).] IP: Logged |
posted June 02, 2006 13:18
Hello Henk,Sieht sehr gut aus!  ET IP: Logged |
jomoon568 True Blue Posts: 61 From: Anglesy, N.Wales Registered: Nov 2005
posted June 03, 2006 11:37
Henk, Nice tractor. Noticed from the picture files listed, he had the Nose badge.Its the wrong colour. Try this site that [Barry and I have put together] for the Correct Badges / Colours. John (IMG)http://www.putfile.com/gaffer1(/IMG)[This message has been edited by jomoon568 (edited June 03, 2006).] IP: Logged |
posted June 03, 2006 12:41
Hello John,A lot of parts on that tractor where chromed in the past. Later on the painted it again bleu, but they used the wrong colour. I think the badge was also completly chromed. Acording to your list I think it had to be no. 3. By the way, always use small letters in a image or link adress and sqaur brakets. Nice site. Where did you find all the information about the history of the brand Fordson? I will put a link on my site to your pages. Regards Henk [This message has been edited by Henk (edited June 03, 2006).] IP: Logged |
posted June 03, 2006 20:12
Hi,In the book "Ford Tractor Story part One" such a Power Major is on a photo. In metallic blue, and with four hole front wheels. I think the color can be OK, and Ford fitted some of the first powers the old type wheels. Why did they change the wheel type anyway? Regards Emiel IP: Logged |
posted June 14, 2006 00:48
Probably because the cast wheels were to heavy, on my FPM laden with Manure. I quite often get stuck in the mud. The Tractor just sinks I have been down to the Front cross member several times. Hard task in getting it out without another tractor to help, winching from trees. Henk I have borrowed it from ? I thought it was this Site but it may well have been YT's. Never mind you can use the info, gratis
[This message has been edited by jomoon568 (edited June 28, 2006).] IP: Logged |
posted June 14, 2006 01:51
Hello Henk, Try this site www.ssbtractor.com/features/Ford_tractors.html Regards Gaffer1
posted June 14, 2006 20:07
Thanks for the link. I have put it on my site. http://people.zeelandnet.nl/hmdetroije/ Regards Henk IP: Logged |
posted June 15, 2006 10:45
Nice site Henk, will have to learn Dutch to get around it. Regards Gaffer1IP: Logged |
posted June 15, 2006 17:29
Hello,No need for that. I made it easy for you, it's also in English. Regards henk IP: Logged |
posted June 15, 2006 19:55
Gaffer, Looked at the site you advised. Lot of incorrect information on there regarding the British Fords. There never was a petrol/paraffin Power Major. Production of these finished in 1955. The Ford 5000 was not an improved Power Major it is a totally different tractor. The researcher seems to be mainly Ford America orientated. ------------------ Kind regards Brian IP: Logged |
posted June 16, 2006 10:55
Brian, Did you look at my site that I first recomended. (IMG)http://www.putfile.com/gaffer1(/IMG) The other site is not mine and I agree with you, like most sites there are a few errors. Regards Gaffer1
posted June 27, 2006 01:33
Emiel , I missed the plot , on your question about the wheels. As thought I had the 3 Hole Cast Wheels which are very heavy. I had another look the other day and I have the 3 Hole wheel on one side and the 4 Hole wheel on the other side. I have the repair Manual for the FPM and that shows 4 Holes as does this topic. So I will ask the question again when did they change from 4 to 3?IP: Logged |
ScottL True Blue Posts: 104 From: Marengo, OH Registered: May 2006
posted June 27, 2006 04:39
Brian and Co, I have a 59 Power Major at home. I have looked at the bottom picture multiple times and was wondering what the device is with the pulley above the dynamo ??? The reason I am asking is my tractor does not have that device and I do not see any picture(s) or mention of it in the ford parts catalog. Thanks, Scott P.S. Clutch is being re-built as I speak and I should have it back this week. Have a car mechanic friend who is going to come over along with my dad and help me try to get her back together. I have been told the secret is level, level, and level and do not force her. IP: Logged |
posted June 27, 2006 09:35
Scott,That is the power assisted steering pump. PAS was an extra and as we have big muscles on this side of the pond, ( ) we did not have it as standard. In fact even with loader tractors, very few were fitted with it. It was more used on the industrial loader versions. The other thing when fitting the clutch is: Tractor in gear, keep turning the engine until the splines go in. PTO in gear, keep turning the PTO shaft until the splines go in. Wriggle, wriggle, wriggle and push!! ------------------ Kind regards Brian IP: Logged |
Barry Thomas True Blue Posts: 497 From: Anglesey, Wales Registered: Jan 2003
posted June 27, 2006 23:05
jomoon,The New Major front wheel evolved from the E27N and was identical but for the dust ring on the internal face for the New Major, therefore you can be sure that the four hole came first. The 3 hole was introduced in 1958 with the Power Major, the reason for this I do not know, perhaps someone else can enlighten us on this. Regards, Barry IP: Logged |
BarryM True Blue Posts: 107 From: Australia Registered: Jan 2005
posted June 28, 2006 08:03
Hi Guys, Re The Front Wheels. The Dealers Part Book of 1958 quotes 'E27N 1015A Front Wheel is replaced by E1ADDN 1015. Effective August 1958'. This would be the change of 4 holes to 3 holes.The Dust Ring first appeared in 1948. This wheel was used for 10 years. Maybe the moulds were just worn out. I can't tell you anymore as Australian tractors never used these wheels. BarryM IP: Logged |
posted August 01, 2006 01:08
Hello,This weekend I bought a book about Nuffield at Panningen called "The Nuffield Tractor Story Vol 1". On page 173 there's a colloured picture of a'n open worked Nuffield, in bright paint and a lot of crome. Seems Nuffield and Fordson had a lot in comment. Regards Henk IP: Logged |
