Topic: Power or Super
rogern True Blue Posts: 8 From: England Registered: Aug 2006
posted August 21, 2006 13:27
Hi Newbie to forum We are trying to find out what we have, the bonnet days Super Major & the front cowl says Power Major.Serial No's Under Injector is 1547441 Near clutch linkage is B5D or BSD On block under Manifold N27C Under seat is E1ADKN994787T1 and C19D any help would be appreciated. Regards rogern IP: Logged |
posted August 21, 2006 19:05
Thats a Power Major, March 1960. Your block is November 27th 1959 All the rest are February/March 1960.Supers did not come out until November 1960. Its easy to tell the difference. Supers have dif lock, inboard disc brakes and a different lift with draft control. ------------------ Kind regards Brian [This message has been edited by Brian (edited August 21, 2006).] IP: Logged |
posted August 22, 2006 10:24
Brian, Thanks very muchRogern IP: Logged |
jomoon568 True Blue Posts: 61 From: Anglesy, N.Wales Registered: Nov 2005
posted August 22, 2006 20:07
Rogern, Just out of interest what is the Model number of your Simms Fuel Injector Pump SPE 4A 75S XXX gaffaIP: Logged |
posted August 23, 2006 11:25
jomoonThe number is: SPE4A75S647 Another number on the bottom is: 330270. What is the significance of these numbers? Regards Rogern IP: Logged |
posted August 24, 2006 10:21
Rogern, It is another way of informing you that you have the correct pump for the engine. This Pump was fitted to both the Power and Super major. [Mine is the previous one to yours i.e. 527 and is fitted to a May 1959 FPM]. It is the last of Simms type before the Simms Mimic was fitted to FSM's in 1962. The number underneath is the Serial Number of the pump.[Mine is 293848 Just before yours] What I was trying to work out was when it changed types, thanks. gaffa[This message has been edited by jomoon568 (edited August 24, 2006).] IP: Logged |
