posted August 03, 2007 15:17
The following links are for the official and original factory service manual for the Fordson Major. These files reside on the www.Fordson.se website which is a Swedish Fordson Forum. All credit for this wonderful resource goes to that forum’s members; I am simply posting the links. The manuals are in English but the file names are in Swedish. Some English language computers do not properly handle the special characters in the Swedish alphabet that have either one or two dots over the letter. In the links below, I have changed those characters in the file name to the ASCII code to help with that potential problem. Once downloaded and saved on your computer, the filenames can be changed to anything of your choice.Julian H.
The link to the thread on the Swedish forum where these links came from:
http://www.fordson.se/phpBB2/viewtopic.php?t=1844&sid=3e25e9d7f34cacd8ff3dd3d161458798
The repair manual links (with English characters substituted):
http://www.fordson.se/1A_Motorkapitlet_Diesel_motor_Verkstadsmanual.pdf
http://www.FORDSON.se/1B_Motorkapitlet_Bensinmotor_Verkstadsmanual_035-067.pdf
http://www.fordson.se/2_Kylsystem_Br%E4nslesystem_Verkstadsmanual_068-114.pdf
http://www.fordson.se/3_Demontering_koppling_V%E4xell%E5da_Verkstadsmanual_115-136.pdf
http://www.FORDSON.se/4_Bakaxel_bakre_transmission_Verkstadsmanual_137-146.pdf
http://www.FORDSON.se/5_Hydraulik_Verkstadsmanual_147-166.pdf
http://www.fordson.se/6_Framaxel_styrning_bromsar_d%E4ck_Verkstadsmanual_167-190.pdf
http://www.FORDSON.se/7_El_Verkstadsmanual_191-224.pdf
http://www.FORDSON.se/8_Magnet_dimensioner_index_supplement_koppling_Verkstadsmanual_225-247.pdf
The supplement links:
http://www.FORDSON.se/1A_Motor_Suplement_Verkstadshandbok_001-031.pdf
http://www.FORDSON.se/1B_Motor_Koppling_mm_Suplement_Verkstadshandbok_032-048.pdf
http://www.fordson.se/2A_Br%E4nslesystem_mm_Suplement_Verkstadshandbok_001-030.pdf
http://www.fordson.se/2B_och_3_Br%E4nslesystem_Delning_av_traktor_mm_Suplement_Verkstadshandbok_031-030_och_001-004.pdf
http://www.FORDSON.se/4A_Koppling_Suplement_Verkstadshandbok_001-016.pdf
http://www.fordson.se/4B_V%E4xell%E5da_Suplement_Verkstadshandbok_016-035.pdf
http://www.FORDSON.se/5_Bakaxel_Suplement_Verkstadshandbok_001-015.pdf
http://www.FORDSON.se/6A_Hydraul_Suplement_Verkstadshandbok_001-024.pdf
http://www.FORDSON.se/6B_Hydraul_Suplement_Verkstadshandbok_025-050.pdf
http://www.FORDSON.se/7_Servostyrning_Framaxel_Suplement_Verkstadshandbok_001-022.pdf
http://www.fordson.se/8_9_Broms_sl%E4p_och_Elsystem_Suplement_Verkstadshandbok_001-012_och_001-010.pdf
http://www.FORDSON.se/10_Hitchkrok_Kraftuttag_Suplement_Verkstadshandbok_001-015.pdf
