Topic: foot throttle
63super True Blue Posts: 5 From: Mackay, QLD, Australia Registered: May 2007
posted October 12, 2007 12:12
Hi everyone, My super major is fitted with a foot throttle that is linked to the hand throttle shaft. I have looked at the parts manual and it doesnt show anything other than a hand throttle.I am Wondering if any one has come across this set up before?IP: Logged |
Mike Kuscher True Blue Posts: 123 From: Worcestershire, England Registered: Oct 2002
posted October 12, 2007 18:41
quote: Originally posted by 63super: Hi everyone, My super major is fitted with a foot throttle that is linked to the hand throttle shaft. I have looked at the parts manual and it doesnt show anything other than a hand throttle.I am Wondering if any one has come across this set up before?
Yes, I've seen it on 3 different Majors over the past 2 years. Every one I have seen has been an 'after market' modification. Rgds, Mike IP: Logged |
posted October 13, 2007 01:00
Mike, Did you notice if the foot throttle worked independently to the hand throttle ie like a foot throttle in a car that returns to idle when released. where as the hand throttle can be set at a constant rpm.IP: Logged |
posted October 13, 2007 08:43
Hand and foot throttle are related and you have to be careful. When you take your foot off the foot throttle the engine will only shut down to the position the hand throttle is set at.Can be embarrassing ------------------ Kind regards Brian IP: Logged |
Oscar Rules All Things Blue Posts: 962 From: The Netherlands Registered: Feb 2002
posted October 13, 2007 09:05
quote: Originally posted by Brian: Can be embarrassing
Do I sense some more Field Memories in the making .....?  IP: Logged |
posted October 16, 2007 17:48
Oscar, you should have known better, this would never happen to Brian ... Right Brian ? quote: Originally posted by Oscar: [QUOTE]Originally posted by Brian: [b]Can be embarrassing
Do I sense some more Field Memories in the making .....?  [/B][/QUOTE] IP: Logged |
Henk True Blue Posts: 502 From: Arnemuiden, The Netherlands Registered: Nov 2004
posted October 16, 2007 22:14
Hello 63super,I have fit myself a foot throttle on my New Major. It works really well. Brian is right you have to be careful when driving both way's. Always keep the hand throttle at the lowest position when using the foot pedal, and when you use the hand version don't put your feet on the foot pedal. The system is different from the one with the hand throttle under the steering wheel, like yours. I have seen the same system at the show at Panningen this summer. Maybe the guy saw it on my site, or we have made the same system without knowing one another. It can be reversed back to original. Regards Henk [This message has been edited by Henk (edited October 16, 2007).] IP: Logged |
