  Cessna Hydraulic Valve
Author Topic:   Cessna Hydraulic Valve
Kjetil
posted February 24, 2008 21:58     Click Here to See the Profile for Kjetil   Click Here to Email Kjetil     Edit/Delete Message   Reply w/Quote
Hi
For my front loader I have a Cessna valve, made in Great Britain.
Anybody have some knowledge of this type of valve? I am looking for a part list or any other information.
I have taken it off the tractor. Is it any good idea to open it and change o-rings etc., or should I just leave it unopened?
Kjetil
posted February 25, 2008 07:58     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
Kjetil,
Do not know your valve specifically but have had some experience of similar valves.
Usually they are made as units and components are not interchangeable, if you need a new spool you need a new housing. If spool valve "O" rings leak it means the spools are worn and replacing the rings will not cure the problem.
I would feel that if you do not have problems at the moment, leave well alone.
