  Roadless retrofit to a Super Dexta
Author Topic:   Roadless retrofit to a Super Dexta
apinot
posted November 14, 2003 05:04     Click Here to See the Profile for apinot   Click Here to Email apinot     Edit/Delete Message   Reply w/Quote
I’m currently evaluating the possibility of converting my 2wd Super Dexta to 4wd (Roadless/Manuele). Where I can get replacement parts for this kit, and how difficult this retrofit will be?
This site is Great.
Regards to all,
Alberto.
Oscar
posted November 14, 2003 11:17     Click Here to See the Profile for Oscar     Edit/Delete Message   Reply w/Quote
Ever since I started this site, no-one has found a Roadless 4WD conversion set and/or converted his Dexta. I've been on the hunt for a set like this for a long time. As for the difficulty of the job: I'd say an experienced mechanic with the right tools could do it in a day.
mikeR
posted November 14, 2003 14:56     Click Here to See the Profile for mikeR   Click Here to Email mikeR     Edit/Delete Message   Reply w/Quote
Its something thats crossed my mind as well. I don't know any thing about them but Allgrip Traction advertise as doing $ wheel drive conversions for Dextas and Super Dextas Tel (UK) 01982 553791. Keep us posted if you do
wfillingham
posted April 21, 2004 15:02     Click Here to See the Profile for wfillingham     Edit/Delete Message   Reply w/Quote
from someone who has just helped do a super major roadless conversion, costs for that were thousands.....and the parts were obtainable.
Given dexta roadless axles/transfer box are non existent, then that makes it considerably more difficult.
I would be interested to find out what Allgrip Traction actually use for there transmission system.
technically, it would be possible to make your own modified front axle from something else (ie. I think an early landrover front axle should be the correct width for example)the diff would be on the wrong side though, so you would then have to turn it upside down, + other nightmare DIY engineering conversion problems), and in fact, the centre diff coupling could be made from other items (for example a modern viscous unit from a modern 4x4 car), propshaft is not a problem either, as these can easily be made. though it would be the transfer box that would be something completly made from scratch, so i would be interested in this part as to how the design is done by Allgrip.
if anyone has got any photo's or details of the Allgrip traction conversion I would be interested to see their design.
The transfer box for the roadless super major was very basic, and the diff unit was in effect a thing with a big spring and lots of asbestos plates. The roadless axle is actually a cut down military axle. CV joints were a nightmare.. new ones were apparently over £600 each!!
I think if you want to find out more about roadless, then speak to David Pantry who specialises in Roadless, and has himself a roadless Super Dexta.
wfillingham
posted April 21, 2004 15:47     Click Here to See the Profile for wfillingham     Edit/Delete Message   Reply w/Quote
in fact, i think if you were completely set on having a 4x4 fordson then you might as well just get a super major. expect to pay at least £4k for the base tractor with roadless kit, then expect to spend about £2k to restore the whole thing, as for that price it will most likely be nearly scrap.
therefore, £6k sould see you get a decent roadless SM, which may then be worth at least £8k. Possibly over £10k if restored to a very high standard.
neilarmo
posted April 21, 2004 21:17     Click Here to See the Profile for neilarmo     Edit/Delete Message   Reply w/Quote
Hi All, Yes Allgrip do make 4wd conversions for MF35's Dextas etc. They use what look like Land Rover front axles.
They have an advert with a couple of pictures on www.tractorsdirect.org.uk . I think they are in Wales. You won't finish up with a tractor with a history but it will be less likely to get stuck !!
Neil
Roadless FSM 6cyl owner
[This message has been edited by neilarmo (edited April 21, 2004).]
apinot
posted November 08, 2004 02:13     Click Here to See the Profile for apinot   Click Here to Email apinot     Edit/Delete Message   Reply w/Quote
Hi Oscar;
I found a Dexta Roadless, which is out of service (engine is not good and sheet metals are beyond repair), but it seem that the front axel and the transfer box may be OK. Of what I saw, it is only missing the prop. shaft. What would be a reasonable price for such rare beauty.
Alberto
Oscar
posted November 08, 2004 07:40     Click Here to See the Profile for Oscar     Edit/Delete Message   Reply w/Quote
Alberto,
The price of an old Dexta is not a matter of common sense but of emotion. There's not much common sense in buying a heap of junk . I have no idea what the Dexta you describe "is worth" in an economical sense, only what I would (in theory) be willing to pay for it (a few hundred euros at most). I agree that it's a relatively rare find, so if you can buy it real cheap then go for it!!
Oscar
wfillingham
posted November 11, 2004 14:43     Click Here to See the Profile for wfillingham     Edit/Delete Message   Reply w/Quote
maybe you could post some digital photo's, personally even if the axle was nearly scrap it would still be worth getting, and rebuilding. maybe need to be careful if say all the insides are actually completely missing, I mean if the cv joints, and diff was actually missing, you might end up spending £k just to get replacement ones...
Oscar
posted November 12, 2004 13:33     Click Here to See the Profile for Oscar     Edit/Delete Message   Reply w/Quote
The axle is half the story. A 4WD Dexta is longer than a standard one because there is en extra segment between (if I recall correctly) the the gearbox and the rear axle housing. This segment controls the 4WD; it has an engagement lever and makes sure the 4WD turns at the rigth speed compared to the rear wheels.
posted November 12, 2004 20:51     Click Here to See the Profile for Johan   Click Here to Email Johan     Edit/Delete Message   Reply w/Quote
I think this is what Oscar means.
I've linked the picture from Stefans website: http://www.fordson-dexta.de
[This message has been edited by Johan (edited November 12, 2004).]
wfillingham
posted November 13, 2004 12:47     Click Here to See the Profile for wfillingham     Edit/Delete Message   Reply w/Quote
yes, that's the transfer box.
Maybe if you buy it, and you did rebuild the parts to retrofit etc it would be interesting to have detailed photo's of the design etc etc. Another part that would be useful for details/measurements etc would be the modified pivot pin area for the axle.
In fact, all the above would be interesting if anyone else has a roadless dexta and had detailed photo's measurements etc for transfer box and axle.
posted November 14, 2004 11:10     Click Here to See the Profile for Emiel   Click Here to Email Emiel     Edit/Delete Message   Reply w/Quote
Hello,
I found on this site some pictures of Allgrip conversions
Regards Emiel
http://www.tractorsdirect.org.uk/VintForSale.htm
alan kelly
posted November 24, 2004 01:11     Click Here to See the Profile for alan kelly   Click Here to Email alan kelly     Edit/Delete Message   Reply w/Quote
hello,i am thinking of selling my 1961 roadless dexta 4wd and a 1964 grey wing roadless dexta 4wd,i am allso thinking of selling the roadless super major 4cyl 1964 grey wing and the roadless major 6/4 grey wing 1964.any of you chaps out there intrested.you may ring me on uk 01407810032
wfillingham
posted January 21, 2005 14:40     Click Here to See the Profile for wfillingham     Edit/Delete Message   Reply w/Quote
did anyone read the recent article in Tractor and machinary about Allgrip Traction. It had detailed info on how he designed the transfer box, and that he does actually use a landrover axle.
I thought his design of the transfer box was impressive, using the chain drive method idea from the modern landrover transfer box. the casing was welded from thick steel.
Although the transfer box looked very tidy, i did not like the arrangement of the front axle, it still looked as though it could have done with some development. Ie. it used an arranegment of parts of the old front axle pivot, then brackets downwards to the landrover axle. i would have though it better if a proper pivot mounting was welded to the axle directly, then to modify the front bracket to bolt to the sump. (ie like an origional roadless).
it also appears he does not use a limited slip diff arrangement of any sort (ie front/back), it seems directly coupled, with the standard landrover series freewheel hubs fitted.
Unfortunately the article did not mention costs, though from the look of it, the engineering of the transfer box looks quite expensive.
I suppose as with all replica/repro stuff, it always depends on the market, and how many people are actually going to buy results of many hours engineering design/labour.
Maybe sometime in the future someone might take a genuine roadless dexta to pieces and replicate various parts, and/or find off the shelf subsitutes for various other parts.
posted January 21, 2005 18:43     Click Here to See the Profile for Johan   Click Here to Email Johan     Edit/Delete Message   Reply w/Quote
In my opinion...
I'm rather looking forward to the future, hoping sometime might take a Reduction gearbox for Dexta/SuperDexta to pieces and replicate various parts, and/or find off the shelf subsitutes for various other parts.
posted January 21, 2005 18:54     Click Here to See the Profile for Emiel   Click Here to Email Emiel     Edit/Delete Message   Reply w/Quote
I read the article. It was a very nice article.
I personally don't like the idea to build such non original farm workshop items onto good original tractors. I don't like cartuning also.
When one will adapt his tractor to 4wd I think he can better take a 4wd axle from a shibaura or some russian tractor. These quite often have portal axles with the reduction in the wheel centre (Like the MF 65 rear wheel drive). That means more clearance under the front axle and it will look nicer with tractor wheel centres instead of car wheel centres.
Regards Emiel
Kiwi Kev
posted July 04, 2005 14:24     Click Here to See the Profile for Kiwi Kev   Click Here to Email Kiwi Kev     Edit/Delete Message   Reply w/Quote
Does anyone have a copy of the story about All-Grip Traction, as published in the Tractor and Machinery magazine, as refered to by wfillingham on Jan 21 2005.
Kiwi Kev
posted July 04, 2005 17:08     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
There are some pictures of a Roadless Super Dexta on the Major board in part answer to Kev's question.
posted July 04, 2005 19:54     Click Here to See the Profile for Emiel   Click Here to Email Emiel     Edit/Delete Message   Reply w/Quote
Backissues can be ordered online, if needed. http://www.tractor-and-machinery.com/
