  question about the differences between Super Dexta's??
Author Topic:   question about the differences between Super Dexta's??
nicholas
posted June 30, 2004 21:52     Click Here to See the Profile for nicholas     Edit/Delete Message   Reply w/Quote
hi folks,
here's a picture of one of my other Super Dexta's. She's in less good shape as you can see.
But my question is:
Who can tell me what the difference is between these two Super Dexta's??????
I really don't know.
tractorfix
posted July 01, 2004 14:34     Click Here to See the Profile for tractorfix   Click Here to Email tractorfix     Edit/Delete Message   Reply w/Quote
Here's my guess. The one in bad shape looks like a 64 to me. The one that has been painted I beleive to be very early 62 Super Dexta because it has the key in the light switch. Of course who knows what happens to these things over 40 years. Mine had an ign. switch from a car, and I saw one on the road today with a captain's chair (velour) from a van on it. At least they both have good tachometers.
nicholas
posted July 02, 2004 09:35     Click Here to See the Profile for nicholas     Edit/Delete Message   Reply w/Quote
Thanks for your reply, tractorfix
I've searched the serial numbers of the two tractors, and found them.
The one in bad shape: C 932217
The one who has been painted: O 9A 313374M
I've searched the serial numbers on the site but i didn't find them.
Maybe Brian can help me?????
Kind Regards, Nicholas
Jos Cuypers
posted July 02, 2004 10:58     Click Here to See the Profile for Jos Cuypers   Click Here to Email Jos Cuypers     Edit/Delete Message   Reply w/Quote
Nicholas,
These numbers are alwayd hard to read, so assuming you have read them correctly :
C 932217 will most probably be 09C 932217 Acc to the 09C it is dated as 1963 but the rest of the number is strange. So you have to give some casting codes to have it dated correctly.
O 9A 313374M looks suspicious as 09A is never used for the Super Dexta as it indicates a 1961 build. Most probably, this Super Dexta is fitted with a Clutch-housing from a standard dexta or maybe the entire rear has been changed (accident). M may indicate that there was a Modification done(my guess).
Can you give us the Engine Number and some casting codes ? If the engine is not 16xxxxx, you may have a Dexta with a Super Dexta nose mounted (The engine number can be found at the Left side just above the outlet-collector).
Jos
tractorfix
posted July 02, 2004 14:09     Click Here to See the Profile for tractorfix   Click Here to Email tractorfix     Edit/Delete Message   Reply w/Quote
That's why I was curios about the key in the light switch. I had never seen a Super D with that
Jos Cuypers
posted July 02, 2004 14:47     Click Here to See the Profile for Jos Cuypers   Click Here to Email Jos Cuypers     Edit/Delete Message   Reply w/Quote
I have checked some official Case New Holland documents :
The first Super Dexta has serialnumber : 09B 710530 and was build April 24, 1962
Acc to the same document, the last Dexta/Super Dexta build is 09D 924433
I got these papers from CNH in order to be able to bring back my Dexta on the road last year.
nicholas
posted July 02, 2004 21:55     Click Here to See the Profile for nicholas     Edit/Delete Message   Reply w/Quote
I've found the engine number
It is: 37116140 O
Maybe you'll know more with this
Kind Regards
posted July 03, 2004 08:45     Click Here to See the Profile for Johan   Click Here to Email Johan     Edit/Delete Message   Reply w/Quote
Originally posted by Jos Cuypers:
"M may indicate that there was a Modification done(my guess)"
-This is interesting!
Can anyone confirm this guess?
When did they put an "M" after the serialnumber?
//Johan.
posted July 03, 2004 18:41     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
Chaps,
I would suspect that Jos has got it right. The 09C number would be December 1963 but the 09A was produced some four months before the Super Dexta was launched.
The light switches also indicate that the 09A is possibly not a Super Dexta as the switch fitted was, again, discontinued in December 1961 and from that date the two switches were used on both Dexta and Super Dexta according to my parts list.
I would suspect that the tractor is either a Dexta with a Super nose or a Super with a Dexta back end. The casting codes will help identify this and if it has a dif lock or not.
However, the "M" is interesting. It could be "Modified" or it could be like the "D" we discovered earlier, a country designation.
What is also possible is that it is a tractor that Ford used for publicity prior to the tractor launch. It seems that there were some Dexta tractors fitted with Super Dexta tin work for publicity photographs.
On YTMag some months ago, was a supposed Super Dexta with a vacuum governor.
Unfortunately the person concerned was not prepared to post details other than the "Dexta" serial number which put the tractor again in November 1961. But he got quite cross when people pointed out that it had Dexta numbers and that Super Dexta tractors were not built until April 1962, saying he had had the tractor from new and it had been sold by the Ford dealer as a Super Dexta and had the correct nose cone.
If Nicholas's tractor is indeed a "modified" one and it can be proved to be so, it will be quite a find.
[This message has been edited by Brian (edited July 03, 2004).]
nicholas
posted July 03, 2004 19:02     Click Here to See the Profile for nicholas     Edit/Delete Message   Reply w/Quote
My tractor has a dif. lock.
But where can i find the casting codes??
posted July 04, 2004 12:38     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
The casting codes are on the left side of the tractor (same side as the diesel exhaust).
They are on the clutch housing above the clutch cross shaft, on the gearbox near the clutch pedal, on the rear axle just in front of the trumpet housing and on the top of the hydraulic lift near the seat.
They are cast into the metal not stamped and are letter/number/letter - C12D, or on later tractors - 3F20.
nicholas
posted July 06, 2004 13:15     Click Here to See the Profile for nicholas     Edit/Delete Message   Reply w/Quote
Could it be that the casting codes start with 957 E?????
These i've found on the right side of the tractor.
posted July 07, 2004 10:47     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
Nicholas,
957E numbers are casting part numbers not codes. See Gerry's post for some ideas.
Jos Cuypers
posted July 10, 2004 14:40     Click Here to See the Profile for Jos Cuypers   Click Here to Email Jos Cuypers     Edit/Delete Message   Reply w/Quote
Nicolas,
It is: 37116140 O
Kind Regards
That's it ? Doesn't it start with 15xx or 16xx ?
Brian,
correct me, but it looks like the engine has been changed and a Perkings Engine in it now!
Jos
nicholas
posted July 13, 2004 13:56     Click Here to See the Profile for nicholas     Edit/Delete Message   Reply w/Quote
The number doesn't start with 15xx, or 16xx.
But the engine number of the tractor in bad shape also starts with 3711.
Could jos be right?
Normally, i think that it were all perkins engines in super dexta's.
Regards, Nicholas
posted July 15, 2004 06:54     Click Here to See the Profile for Johan   Click Here to Email Johan     Edit/Delete Message   Reply w/Quote
"Normally, i think that it were all perkins engines in super dexta's."
According to the book: "FORDSON DEXTA 957E's 1957-64 (by Allan T. Condie), Ford cast the blocks and heads at the Dagenham foundry.
Then it was Perkins job to actually "made" the engine.
So you can say that all Dextas had Perkins engine.
posted July 15, 2004 08:22     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
Johan,
That is not strictly true. Ford tested the P3.144 and it did not come up to their specifications. They specified several design changes before using it in their tractor. Fuel pump and oil pump to name but two. Perkins then made the engine to Fords specification.
Jos Cuypers
posted July 18, 2004 14:04     Click Here to See the Profile for Jos Cuypers   Click Here to Email Jos Cuypers     Edit/Delete Message   Reply w/Quote
Nicholas,
do you have some casting-codes ?
It looks like both engines were replaced by or real Perkings Engines or maybe by engines from a Massey Ferguson (Sorry folks for this un-polite word)
Jos
posted July 18, 2004 17:51     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
Jos
I think a bucket of warm water and some nice carbolic soap for mouth washing is required
Jos Cuypers
posted July 19, 2004 10:24     Click Here to See the Profile for Jos Cuypers   Click Here to Email Jos Cuypers     Edit/Delete Message   Reply w/Quote
Done
but I used "seawater with Oil"
Jos
Originally posted by Brian:
Jos
posted July 21, 2004 08:05     Click Here to See the Profile for Johan   Click Here to Email Johan     Edit/Delete Message   Reply w/Quote
"Ford tested the P3.144 and it did not come up to their specifications. They specified several design changes before using it in their tractor. Fuel pump and oil pump to name but two. Perkins then made the engine to Fords specification."
Well...
Of course Ford set up some demands to buy the product. But after all it is a Perkins construction.
I have noticed that the 3-152 engines that Perkins delivered for the tractor: "Volvo BM 320" (year 1961-1964) did have an improved lubrication system for the camshaft, in comparison to the one for Dexta 3-144 engines.
Johan.
