  What do I have? Dexta or super dexta?
Author Topic:   What do I have? Dexta or super dexta?
Peter Walter
posted August 03, 2004 23:38     Click Here to See the Profile for Peter Walter   Click Here to Email Peter Walter     Edit/Delete Message   Reply w/Quote
Hello
I am a new owner to a -64 Fordson tractor but I´m unsure about what it is. The serial number is 09D927342 and the engine number is 37116140 0 (or maybe O). What kind of engine do I have.
Thanks for any answers
Pewa
Speedy
posted July 06, 2005 17:55     Click Here to See the Profile for Speedy     Edit/Delete Message   Reply w/Quote
Originally posted by Peter Walter:
Hello
Pewa
A Fordson Dexta. Only decided to answer this as my serial is 09D 927613 Location Denmark 9500. Maybe you are located close.
Jos Cuypers
posted July 07, 2005 08:14     Click Here to See the Profile for Jos Cuypers   Click Here to Email Jos Cuypers     Edit/Delete Message   Reply w/Quote
Peter, Walter,
There is no link between the serial number and being a Standard or Super Dexta.
The difference can be found in the Engine number.
The standard Dexta has engine number 150xxxxx and the Super Dexta has 160xxxxx and the Petrols start with FPL27xxxx.
All other numbers are indicating a "foreign" engine (other equipment or Perkings or MF spit spit spit)
Jos
See also => http://fordson.freeweb.nl/ubb/Forum5/HTML/000313.html
lars
posted July 12, 2005 18:19     Click Here to See the Profile for lars   Click Here to Email lars     Edit/Delete Message   Reply w/Quote
hello
I have a dexta the serialnumber is 957E 9398
and engine number is 1409995 the name Monocyl is casted on block and head.
Is it a F3144 ?
posted July 13, 2005 09:42     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
Is the serial number you quote stamped on the flange behind the starter or cast into the clutch housing? If it is stamped your Dexta would be a 1958, if cast it is a casting part number and is no use in dating the tractor.
The number and name on the engine seem to indicate a "non Ford" item. This could be a Perkins replacement and we will have no data on which size unit you have.
lars
posted July 13, 2005 20:57     Click Here to See the Profile for lars   Click Here to Email lars     Edit/Delete Message   Reply w/Quote
serialnumber is stamped on vertical in frontend of clutch house .
Other cast code:
gearbox F15B
rearaxel left F17B
rearaxel rigth F13B
hydraul D6B (difficult to se)
posted July 14, 2005 06:23     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
Yes you've got a April/May 1958 made tractor. Thats why the serial number looked a bit strange, she is very early. Full production only started in January that year.
The original engine would have been an F3.144 and all casting for this and all Dexta engines were done at Fords own casting shop at Dagenham. Only the smaller parts like manifolds were Perkins built.
posted July 17, 2005 09:04     Click Here to See the Profile for Johan   Click Here to Email Johan     Edit/Delete Message   Reply w/Quote
The serialnumber can be difficult to locate on some tractors, especially if the tractor is equipped with a front loader.
However... I think you (Peter Walter) have a 3-152 engine. As far as I know only Ford used the 3-144 engine.
After all, Dexta is a quite rare tractor in Sweden.
By the way... -What fuel injection pump do you have?
Regards Johan.
www.Fordson.se
[This message has been edited by Johan (edited July 17, 2005).]
lars
posted July 17, 2005 17:11     Click Here to See the Profile for lars   Click Here to Email lars     Edit/Delete Message   Reply w/Quote
early F3.144 ?
The engine number 1409995 is very close to 150xxxx
hope someone with early -58 cold tell.
In a old topic 07 mars 2003:
``Firstly the castings were made by Fordson, which are stamped "Monocyl". These include the block the head and sump´´
Foto from my engine
And one from fordson-dexta.de with monocyl on head.
[This message has been edited by lars (edited July 17, 2005).]
