Topic: perkins AD3-152
Ole True Blue Posts: 55 From: Norway Registered: Jan 2004
posted January 27, 2005 14:44
I have problems with my super dexta engine. it smokes bad it makes starnge soundes. I was woundering: does a perkins AD 3-152 (MF 135) fit a Super Dexta? (with changing the oilpan and the adapter plate)IP: Logged |
posted January 27, 2005 17:50
It will fit but you may have to change a few parts like fuel pump (DPA on Fergy), front mounting plate, timing cover etc. Flywheel will be different as well.Don't forget to immerse it for at least a week in strong disinfectant so as not to pass anything nasty on to your Blue Beauty.  [This message has been edited by Brian (edited January 27, 2005).]
[This message has been edited by Brian (edited January 27, 2005).] IP: Logged |
posted January 28, 2005 07:02
Brian is right! An "AD 3-152" -engine is direct injected. Therefor you have may have to change the whole engine, including the dieselpump. All blocks on 3-144, and 3-152 engines fits to your old timing gear case, to your Super Dexta's flywheel and clutch housing, as well as to your old oil sump.
[This message has been edited by Johan (edited January 28, 2005).] IP: Logged |
Mark Burgess unregistered
posted January 28, 2005 07:37
Ole, Brian is also right about disinfecting the M@@@y F@#%&^*n before you attempt to put it on a Fordson Dexta. Makes for a nice job! MarkIP: Logged |
posted January 28, 2005 14:14
the plan was to change whole engineIP: Logged |
