Topic: LUCAS GENERATOR
posted February 06, 2005 21:13
Hallo, Does anyone know how to recognize the right Lucas Generator for Fordson Dexta. I have found some digits: LUCAS 227 15H 34029 LRD 100 22715 23/80/B My generator works sometimes, sometimes not. Maybe the generator is the fault, but it could be the control box. First of all, i want to know if it is the right generator, maybe the generator and control box simply can't work together. IP: Logged |
ger-man True Blue Posts: 280 From: Germany Registered: May 2003
posted February 07, 2005 06:26
Johan, your Dexta is fitted with a 22 Ampere generator. The standard type was a 11 Ampere generator. The original generator was a Lucas LDR101. StefanIP: Logged |
posted February 07, 2005 07:18
Well... I think my control box is about original. At least it seems to be, but i don't know how to check that (by digits, letters or codes) either. Do you think i have to change the generator, or can it work together with the control box? There is very tight space around this generator. My generator are about ø101,6mm (4 inch) outside diameter. Are LRD100 increased outside diameter, in comparsion to LDR101? (My control box have four connections (D, E, A, and F.)
[This message has been edited by Johan (edited February 07, 2005).] IP: Logged |
posted February 07, 2005 08:25
Johan, A 22 amp generator will work OK with an 11 amp regulator. Its an 11 amp dynamo with a 22 amp regulator that causes problems. There is no difference in the size of the Lucas 21 amp and 11 amp. the 11 amp has a closed brush plate the 22 amp has a ventilated one. I don't think 11 amp units are available any more.If you have the old style regulator it will be 11 amp. They did not make a 22 amp one until the '000 series and then it was the later type.
------------------ Brian IP: Logged |
posted February 13, 2005 11:33
Today i have solved the problem. I have bougt a new control box, changed and tested it. Now my generator works just fine. Control box: LUCAS 12V / 22A NCB 130 RB 340 Generator: LUCAS 12V / 22A 227 15H LRD 100 This control box is fitted onto the plate called "957E-9097", instead of onto the cover "957E-11871" as describes in the manual.
It is fitted with two 2 1/8" (54mm) long screws, diameter ø3/16" (ø4,8mm). Between the control box and the plate (957E-9097) there is distances ø1/2" (ø12,7mm), length about 7/8" (22,2mm).
[This message has been edited by Johan (edited February 13, 2005).] IP: Logged | |
