  Reverse Gear
Author Topic:   Reverse Gear
James
posted June 21, 2005 12:23     Click Here to See the Profile for James   Click Here to Email James     Edit/Delete Message   Reply w/Quote
Does anyone have experience of a Dexta stuck in reverse and how to free it please?
Jos Cuypers
posted June 21, 2005 13:04     Click Here to See the Profile for Jos Cuypers   Click Here to Email Jos Cuypers     Edit/Delete Message   Reply w/Quote
James,
most probably, the reverse is stuck due to the levers not beeing centerd in the connectors, do following :
- Remove the top plate (plate with the 2 gear levers) by releasing the 4 screws.
- Using a big screwdriver, shift the connections to the center (puts everything out of gear)
- Replace the plate with the 2 levers back
ready
Good luck
Jos
[This message has been edited by Jos Cuypers (edited June 21, 2005).]
dewaltdisney
posted June 21, 2005 14:18     Click Here to See the Profile for dewaltdisney   Click Here to Email dewaltdisney     Edit/Delete Message   Reply w/Quote
Hi Joe,
My Dexta has just got stuck in first gear. Is it the same procedure that you have explained here please
DWD
Originally posted by Jos Cuypers:
James,
ready
Good luck
Jos
dewaltdisney
posted June 21, 2005 14:24     Click Here to See the Profile for dewaltdisney   Click Here to Email dewaltdisney     Edit/Delete Message   Reply w/Quote
Oops, Sorry I meant JOS
DWD
Originally posted by dewaltdisney:
Hi Joe,
DWD
mikeR
posted June 21, 2005 14:29     Click Here to See the Profile for mikeR   Click Here to Email mikeR     Edit/Delete Message   Reply w/Quote
i am no expert but yes mine gets stuck all the time its due to wear on the bottom of the gear stick. search the site for earlier posts someone posted a set of phots on how to weld up the end of the gear stick to solve the problem. i did it to mine and improved it no end it just needs a final tweak when i get time. it helps if you take care with changes being positive in your action. you will soon get the hang of it when you have had the thing off a few times!!!!
dewaltdisney
posted June 21, 2005 14:43     Click Here to See the Profile for dewaltdisney   Click Here to Email dewaltdisney     Edit/Delete Message   Reply w/Quote
Great,thanks Mike
Yes, I have just had a look and found them. I have just got nmy Dexta and I am still in a steep learning curve. The tin is tatty but I love it already. I have a mower connected and I am half way through my paddock when it got stuck in gear. I will have a go at doing this fix with the gear shift and I am relieved (at the minute)that it seems to be a commion problem. You are right in that I do not think I selected first properly.
Thanks again
DWD
Jos Cuypers
posted June 21, 2005 16:21     Click Here to See the Profile for Jos Cuypers   Click Here to Email Jos Cuypers     Edit/Delete Message   Reply w/Quote
Folks,
these are some links about the "very common" issue:
http://fordson.freeweb.nl/ubb/Forum5/HTML/000093.html
http://fordson.freeweb.nl/ubb/Forum5/HTML/000182.html
Jos
dewaltdisney
posted June 21, 2005 17:37     Click Here to See the Profile for dewaltdisney   Click Here to Email dewaltdisney     Edit/Delete Message   Reply w/Quote
Hi again,
Well I stripped down as suggested and found that it was the ball joint on the main gear slector stick that was stuck. I coudl not figure out what was jamming it and after messing around trying to get the springs off it suddenly came free. I Bolted it back and the gear sfifting seems okay although a bit notchy.
Am I missing anything here or could it have been caused by some fouling?
DWD
posted June 22, 2005 21:40     Click Here to See the Profile for Johan   Click Here to Email Johan     Edit/Delete Message   Reply w/Quote
Well...
Maybe the bottom of your main gear selector stick is worn.
If so, a brand new main gear selector stick is aviable from New Holland (Ford).
NH-81717916 (957E-7210-C)
