  super dexta power steering
Author Topic:   super dexta power steering
goman 5000
posted October 19, 2006 18:33     Click Here to See the Profile for goman 5000   Click Here to Email goman 5000     Edit/Delete Message   Reply w/Quote
will a power steering pump on a massy ferguson 135 fit on the super dexta perkins engine
clarence arnold
posted October 19, 2006 19:37     Click Here to See the Profile for Brian   Click Here to Email Brian     Edit/Delete Message   Reply w/Quote
First of all the Dexta engine is NOT a Perkins! It is a collaboration between Ford and Perkins.
This means that although the two engines are similar there are lots of differences.
Ford made all the major castings at Dagenham and shipped them to Perkins to be assembled. Parts of the Perkins engine like the oil pump for example can be fitted to a Dexta but they require some modification.
The timing cover and back plate are also different.
It is possible that the pump might fit but you would need to modify it unless it was a belt drive one when you would have the brackets and drive pulleys to change.
You might find that the steering rams bolt straight on though.
Another thing I heard for the first time the other day that is very interesting. Perkins made a gas engine to fit in the MF35. Do you have any details of that beastie? Or is it just a mis-identification of the gas engine fitted to that tractor.
goman 5000
posted October 20, 2006 23:39     Click Here to See the Profile for goman 5000   Click Here to Email goman 5000     Edit/Delete Message   Reply w/Quote
hello brian
thanks for the information,i could not find a place to bolt the pump.about the perkins gas engine i do not know do you know where i can get the super dexta badge that goes on the front of the tractor
thanks
clarence
clarence arnold
tmac
posted October 21, 2006 15:09     Click Here to See the Profile for tmac   Click Here to Email tmac     Edit/Delete Message   Reply w/Quote
Like Brian said the gear driven steering pump wont fit, if it is gear driven pump the Dexta has no place on the Acessory gear housing. The MF 35/135 Perkins has a completely different Acy gear housing than the Dexta engine. The MF35 gear case can't be fitted to the Dexta tractor either as the MF 35/135 gear case will not fit the Dexta's hogshead (front axel mount).
Unless you are using a loader there is NO need of PS on a Dexta for most normal uses, unless your left arm is disabled.
Now on the Perkins Gas 3 I seen one in the junk yard on a MF 135 looks to be the same engine with the exception of being a gass pot fuel burner and what goes with that setup.
