posted October 22, 2006 00:44
Hi There,I have a mid-1960s Ford Super Dexta.
Everytime I want to start it, I have to hook the battery to a charger.
This started happening almost a year ago, and I haven't been able to get past the problem.
Since the problem started:
I have changed the battery. New battery worked fine for the first half dozen starts, then died.
I have changed the solenoid. The old one was overheating, wires melting solder... I did not find an original part, but the people at Fisher gave me an old (1970s) Ford truck part, which seems to work. The machine starts when the battery is charged.
I have taken the generator off and pulled it apart to inspect it as per the manual. It seems in good working order. I tried testing the current coming out of it, but fear I don't have the right kind of volt meter, as I get no reading at all.
I have followed the wiring but lose track of where the striped red and white wire goes. The yellow wire ties into the solenoid (I think).
Since the problem started, we have dismantled the display panel (I was fixing another problem), but everything on the panel seems to be in good order. There is one light that used to light up but doesn't anymore (a clue?)...
I wonder what I'm missing. Please advise.
My guesses:
The tractor is positive ground. I've tried reversing the wiring on the solenoid - doesn't seem to help.
The wiring - it's all taped together and I wanted to avoid pulling it all apart, since most of the wiring seems to be working alright.
That little light - it used to come on and then go off. I think it indicates temperature - at least, it used to come on if the tractor started getting hot...maybe I was misreading that. When we put the display back together and it didn't work, I didn't worry - just a little light, right?
Would appreciate your help...
Danny
