posted April 03, 2007 22:42
Brian,I did not realize that you had any experience with the SOS. Since I respect your opinion very highly I am hoping you know as many SOS tips Aas you do tips on the Major.
I posted on the miscellaneous board that I bought a Ford 881 Gold Demonstrator with a SOS. The SOS on the tractor is questionable as the shifter is apart when I bought it. I have access to three spare tractors with a SOS so getting a new shifter and parts is not a big deal. I bought the Ford parts, owners, repair and SOS manual.
Since I am un-aware of the condition of the SOS and have heard it is a very expensive and hard transmission to work on. I was wanting to know if you know a good starting point to diagnose any problems or if there is anything I should look for.
The top cover and all cables except the PTO cable are off the top of the SOS housing. The SOS did not have any oil in it when I bought it, but nothing is rusted on the SOS. I am presuming the seals are probably bad if it has been without oil for a long period of time.
Is there anything I should check on the SOS while the top cover is off ??
Should I just change the filter, clean the suction tube at the bottom and fill her full of New Holland oil and see what happens ??
The SOS manual shows how to take all of the pressures etc but it looks like the transmission and tractor need to be running to do that.
Thanks,
Scott
