![Stress :stress:](./images/smilies/stress.gif)
![Image](http://i836.photobucket.com/albums/zz287/TheSwanndriGuy/DSC00554.jpg)
As you can see the lower of the two frost plugs at the back of the block is leaking.
![Image](http://i836.photobucket.com/albums/zz287/TheSwanndriGuy/DSC00555.jpg)
Trying to replace the frost plug without spliting the tractor would nearly be as hard as reseting the valve clearances after retorquing the heads on a TS 3
![Run away :run:](./images/smilies/runaway.gif)
Apart from that, the clutch plate is Ok, but the pressure plate is worn out as the pto plate is perminantly bonded to it. TSG.
