Last weekend I use my lift after quite some time. I had my 4 cylinder SuperMajor engine in the lift.
It lifted fine, but when the lift lifted the engine and kept it high, it made quite some noise. It's hard to describe,
but it sounded like a high tone.
The rear axle leaked some oil at the raised pto (i think), which I hadn't discovered before with the lift/PTO not engaged.
Back home I noticed, the oil level was above maximum. Could this be the cause of the sound and of the leaking?
What's the danger of having the oil level above maximum?
After the gearbox rebuild, I filled her up to max. After looking at the oil levekl in the rear axle, I noticed the oil level in the
gearbox was dropped a bit...I hope the gearbox oil is not droppng into the rear axle...
