wireing trouble
northermajor
wireing trouble
Post by northermajor »
hi im having a problem with the wireing of my super major,ths switch on the top of the starter motor gets red hot and melts t,he wires ,when the starter lever is pressed and wont turn over. when you operate the solenoind manuly and hold the lever down the engine flys round any ideas anybody thanks
Welcome to the board.
The switch on top of the starter only switches the solenoid on so there should be no "power" passing through it, only a very small current. Nowhere near enough to melt wires. Somewhere you have a dead short to earth.
Of the two wires to the switch, one is power from the ignition switch, the other is feed to the solenoid. As you do not get clouds of smoke and burning when you turn the ignition on, it would indicate that the wire from the ignition switch to the starter is OK.
As your problem starts when you press the starter switch, it would indicate that the problem is in the single wire to the solenoid small terminal.
Try another piece of wire from the switch to the small terminal. If everything works then your first wire is faulty. If everything smokes, then your solenoid is faulty.
northermajor
thanks for the reply, i have the two ring terminals from the loom on the big starter/ battery wires noting on the small terminal is this correct its not clear from the wireing diagram thanks
JC
Post by JC »
The wire from the switch on the starter should go to the small terminal on the solenoid. If it's hooked to the big terminal on the starter side of the solenoid, that would explain where the smoke is coming from.
northermajor
thanks i think you'v solved my problem will change it tommorow thanks again
