Nick,
Are you still looking for a pump?
http://www.ebay.co.uk/itm/FORDSON-MAJOR ... 2ebd2d92d9
SSuper Major Minimec
Re: SSuper Major Minimec
Hi brian, I have found a pump, but i did see this and wondered about bidding on it to keep as a spare just incase. What are they worth?
I was bidding on this one and got out bid
and had no Internet signal to go higher.
Kev
Kev
Whilst we're on the subject of minimec pumps..... My one feels like its pumping strong on 3&4 but feels weak on 1&2, would this be the pump or injectors?
Kev
Kev
Injectors would be my first thought, 3 and 4 could have partially blocked nozzles.
Just out of curiosity .... would there be any advantage to replacing the vacuum gov Simms injector pump on my PM with a minimec pump
'59 Power Major
Ancient Smurf
Ancient Smurf
Not really, you might have to change the block, manifolds, throttle linkage, cylinder head to get around 2hp. The pump alone is not the answer.
Thanks, good to knowBrian wrote:Not really, you might have to change the block, manifolds, throttle linkage, cylinder head to get around 2hp. The pump alone is not the answer.
'59 Power Major
Ancient Smurf
Ancient Smurf
