SSuper Major Minimec
Nick,
Are you still looking for a pump?
http://www.ebay.co.uk/itm/FORDSON-MAJOR ... 2ebd2d92d9
Nick
Re: SSuper Major Minimec
Post by Nick »
Hi brian, I have found a pump, but i did see this and wondered about bidding on it to keep as a spare just incase. What are they worth?
Kre1979
Post by Kre1979 »
I was bidding on this one and got out bid :( and had no Internet signal to go higher.
Kev
Kre1979
Post by Kre1979 »
Whilst we're on the subject of minimec pumps..... My one feels like its pumping strong on 3&4 but feels weak on 1&2, would this be the pump or injectors?
Kev
Injectors would be my first thought, 3 and 4 could have partially blocked nozzles.
whirly
Post by whirly »
Just out of curiosity .... would there be any advantage to replacing the vacuum gov Simms injector pump on my PM with a minimec pump :?:
'59 Power Major
Ancient Smurf
Not really, you might have to change the block, manifolds, throttle linkage, cylinder head to get around 2hp. The pump alone is not the answer.
whirly
Post by whirly »
Brian wrote:Not really, you might have to change the block, manifolds, throttle linkage, cylinder head to get around 2hp. The pump alone is not the answer.
Thanks, good to know :!:
'59 Power Major
Ancient Smurf
