Super dexta fuel pipework
Mossside
Post by Mossside »
Hi people
Looking for pictures of the super dexta 1964 fuel pipework as not sure if i have the correct fuel tap etc etc .
I also need pictures of the cold start pipework on the inlet manifold many thanks in advance a newbie as everything i order does not fit :-(
Mossside
Re: Super dexta fuel pipework
Post by Mossside »
Sorry just read the rules i am from the UK
kiwiland dexta
Post by kiwiland dexta »
Hi Mossside, This is the parts list image for the Dexta fuel system, hope it helps.
Kind regards
Derek
Mossside
Post by Mossside »
Derek
Thanks for the help it maybe that i have an incorrect fuel pump as there is no where to attach the pipe from pump to inlet manifold and the pipe from fuel pump to tank is too long so this may be my problem .
Thanks for the help
Mick
PghBill
Post by PghBill »
Mosside,
The pipe to the air intake comes from the primer bulb on the fuel tap under the fuel tank.It does not go to the lift pump. :D
PghBill
Post by PghBill »
https://postimg.cc/gwvNjpqB
Here's a better pic
Mossside
Post by Mossside »
Thanks i have the wrong fuel tap then :clap:
