Wheels stuck
Kjetil
Wheels stuck
Post by Kjetil »
I have a NP Super Major without engine.
When I try to move it, the rear wheels are locked.
I removed the brakes on one side, one wheel of the ground, made no difference.
Put the gear in free, no difference.
When i rotate the input axle on the front transmission, i can make the rear wheel rotating.
Any ideas?
Kjetil
Super Major
Post by Super Major »
There may be two gear, maybe the change is being recorded and a few millimeters are woven two gears at once, is only a guess of course, you should try to remove the cover and see the change.
sandymac
Post by sandymac »
I think you need to remove both side brakes.
Ian
Post by Ian »
if one brake was stuck on it should still move due to the differential, unless that was locked on also
sandymac
Post by sandymac »
Ian wrote:if one brake was stuck on it should still move due to the differential, unless that was locked on also
Not with both wheels on he ground?
JC
Re: Wheels stuck
Post by JC »
Kjetil wrote:I removed the brakes on one side
Did you make sure that you took all of the discs off? If the last one is still on, and rusted to the housing, it still won't move.
Kjetil
Post by Kjetil »
I lifted off the cover on the rear end, and all of the sudden, the right hand wheel will now rotate.
When I rotated the wheel to check the hydraulic pump, it seems only to be water comming out.
We have had a long cold winter, so may be the big teeth wheel has been frozen.
Left hand is still locked, but I will open the brakes on that side as well.
