After working on my major trough the winter, I have made a test ride yesterday. Today I was disappointed because I found that there are two oil leaks. One is between the block and head on the right front side just above the fuel pump. (the upper red line on the picture) I had notice it before but thought it was the fuel pipe connection on the injector. So now it seems to be a leaking gasket I think. That means removing the head.
Do I have to remove and tighten the head bolts in a special order of rank?
Witch gasket do I need. My engine number is before 1425097. That’s when they changed the copper asbestos in a thin steel gasket. Is de gasket still copper asbestos or is there a replacement?
I will bring up the other problem on a new topic.
