I just bought this off eBay.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... SA:US:1123
I'll let you know what happens when I get it.
Like Dandy Dave says, "Sometimes chicken and sometimes feathers".
eBay Injector Pump
Some days feathers, some days Chicken Cordon Bleu
I picked up the pump at the post office today.
It turned kind of hard, so I took the side cover off to see how the plungers looked.
They looked OK, and they all moved, so I squirted a little PB Blaster on them and put the cover back on. It still turned hard. I thought that the cam box may be a little dry after sitting for so long. I filled it with oil through the leak off hole, then it turned over the way I thought it should.
I mounted it on my Power Major to test it.
When I bled it, I only got fuel out of the first three. I thought, Now I know why I got this so cheap. I pushed the excess fuel button and cranked it a little more, and the fourth one started pumping, too.
Here's a video of me trying to start it after I got the injector lines tightened.
http://www.youtube.com/watch?v=RzLCLTaNP3k
Sorry about the quality. I just used the video function on my camera and I'm not much of a camera man.
I have a new saying for you, Dandy Dave. "Even a blind dog finds a bone every now and then"
Thanks, guys.
She needs a little more than paint. Its Brian and J-P's favorite model, the ASP. The back end is Power Major, the front tombstone weight and hood are Super Major. The engine block is older than the rest of the tractor and it has a Mk. 1 head. It also has power steering off of a late 60's or early 70's 3/4 ton, 4x4 Ford pickup. I have a few parts that I can use to make her closer to original, but she will probably never be all original.
Does a Nuffield use that same pump and coupling, Kim? I think this pump may have been off of an industrial engine, because of the lift pump and the accessory drive off the end of the cam.
