Forest Tractor construction
Re: Traction device
Aviator I'm having a hard time understanding from your explanation how this traction device works. Would you try and explain a little better.
Does it come down on the ground by some hydraulics? Does it pick your tractor up out of the mud and push it forward or backward by hydraulics? How can something that is bolted to the bottom of the tractor help with traction.
Your fabrication of this device is great, I just don't understand the mechanics, sorry.
See ya
Mark
Mark
I think the meaning gets lost in the translation. (Transmission Device) It is a transmission gard, or belly pan that also supports the hydraulic pump, that is driven off of the PTO, for the log loader that will come later. With that said, the log transport wagon will also have to be towed by some point on the tractor. Dandy Dave!
Re: Traction device
Traction device does not contain any hydraulic activity. It is attached to the hook which later turned logs with a trailer. At the same time frame towing device protects hydraulic pump connected to the output shafts. Traction device on the bottom of the cover plate to protect rear of the tractor hydraulics compartment below the pump suction connection and the degree of hydraulic hoses. I hope this clarified a little traction device approach.Mark wrote:Aviator I'm having a hard time understanding from your explanation how this traction device works. Would you try and explain a little better.
Aviator,
I think Dave said it best "the meaning gets lost in the translation." When you said "traction" I thought you meant a device somehow that would help the tractor to not spin it's wheels in mud or snow.
I see now what your are talking about.
Thanks Dandy Dave.
Thanks Dandy Dave.
See ya
Mark
Mark
I took the charger out of the original, as do I install the AC charger. It is a space for quite a bit enhancer hydraulic pump has been installed. So resolving the matter so that the alternator will build a new stand, and as you've also done so, install the crankshaft from the double pulley. Then the alternator has its own belt and the belt contact while the charger is greatly improved.Dandy Dave wrote:I see that you have removed the dynamo, to install the power steering pump. How do you plan to re-charge the batterys? My power major has two pulleys on the crankshaft end, and the dynamo stays where it was originally installed. Dandy Dave!
True talkDandy Dave wrote:That first trip around the block after all that work sure does feel good. Doesn't it.Dandy Dave!
