Hi all, tractor is virtually finished now up and running this weekend, power steering decided not to work so will look into that but quite pleased with the end result so took the oportunity to get both tractors out for a couple of pics.
Regards Len.
Like we say back here in the states. Ssswwweeeeeeeetttt. Looks like you just need to get the left grill and light in as the bonnet appeared in the last picture. Dandy Dave!
Cheers guys, henk yes I do know the L/H drop arm is not right a friend of mine is looking for a correct one so that he can swap with me ( his has been welded), Essex Pete the pipes are as they were when I stripped it however the only time that I had it running was without the power steering belt on as I had nowhere to fix the ram to (it was attached at the rear of the loader frame) si hand on heart I cannot say that it was pied up correctly before hand or indeed it it worked before, do you know which way round the pipes should be mine is the L/H pipe at the pump goes to the uppermost point on the ram.
Regards Len.
