"If I was 3 thousand miles closer I'd volunteer my services to help you haul it out! It would be a shame to see it rot away or be scrapped".
Kim aren't you about tired of living in Mass. Wa is a great state to live in. Ever thought about moving?
No need to worry about scrappers getting it, most are in to big of a hurry to load and dump to go after this tractor
This real work!
Ben I think it is going to take more than my chainsaw to get this rig out!! Then again Iam not sure I can get a chainsaw up that mountain!;) I could hardly walk up there carrying a camera!!
What I was thinkin this will either have to come out under its own power or heavy equipment like a cat. The problem with a cat is the high cost to get it there maybe more than the tractor is worth.
What I was thinking is to put another engine on a trailer like system that would fit the 3 pt hitch then run a drive shaft to the PTO then use that to power it out. The loader bucket is stuck into the dirt and that would have to lift up. The hyds for the loader are a separate pump on the front of the engine. But it does have a DAR valve. With the PTO turning it would have hyd pressure to that valve. Then hook the loader into the DAR tractor system to lift the bucket.
Iam not sure that Iam up to this type of job any more. But you know what, if this tractor stays up there a few more years it is going to belong to ancient history and a lost civilization. Just an artifact of time right. As of now I only know of 3 people that knows where it is at!! Then if the owner is part of the dearly beloved crowd that only leaves 2 of us!!
