icom102
Posts: 232 Joined: Sun Jun 06, 2010 5:32 pm
Post
by icom102 » Fri Sep 17, 2010 11:16 am
What size are the rear tyres on a major i cant make out the size on mine all i can see is 13 6 space 12 space 36
Posts: 2091 Joined: Wed Apr 16, 2008 8:56 pm
Post
by henk » Fri Sep 17, 2010 12:37 pm
The standard size is 12.4 x 36
icom102
Post
by icom102 » Fri Sep 17, 2010 1:25 pm
Ok cheers the web site i am lookin at for tyres is asking for
Tyre Width
Aspect Ratio
Rim Diameter
Load Index
Speed Rating
any ideas?
Post
by henk » Fri Sep 17, 2010 5:15 pm
36 inch is the rim dia.
12.4 is the tyre width if im not wrong.
Speed will be very slow.
Aspect Ratio ??????
Load index depents on what you will use them for.
The numbers of ply is the steel wiring in the side of the tyre.
