OK, I posted this in the wrong section of the forum. I thought I posted it in the Dexta section, but some way I posted it wrong.
But anyhow the oil change is now done. I could not get out the drain plug as the trailer hitch was in the way. I removed the drop down part, but couldn't find a socket that would fit up in there and on the plug.
I ended up using three times the amount of oil
First I drained the old oil through the aux hydraulic, I just unscrewed the line for the front loader and let the hydrualic pump do the rest. Filled it two times with fresh oil, drowe it around and worked the hydraulic some and drained it the same way. The last time I bolted everthing back up, filled it with oil for the last time and got out all the air from the front loader system.
Wow this made a difference
The hydraulic is much faster, it holds it position much longer and the flow control works the way it shoul.
The old oil was milky white, and very thin
This will have to do until summer is back
Tom T. Winchester
Little did I know that all those days passing was life itself!
