Injector pump fixings
marcusgs
Post by marcusgs »
Hi, Can someone confirm to me that the dexta injector pump is fitted with studs please? I have 3 but can't find any more!
Thanks,
Mark
john.n
Re: Injector pump fixings
Post by john.n »
think its 5 studs. there is a good one to find round the back of the pump.
are you trying to remove the pump?
regards,
marcusgs
Post by marcusgs »
Hi John,
No, I'm trying to re-fit the pump, but seems like I only have three of the five studs :cry:
Seems like I need to beg or make two new ones then!
Thanks,
Mark
Post by Jerry Coles »
Use your exisiting studs to secure the pump on the engine block side (limited depth to keep away from gear wheels) but you could use bolts on the outer two holes but again check the clearance.
The two lower studs on the block side are very awkward to access - you need a long extension and long fingers!
Bath
UK
