Hello,
I`ve taken some picturers of my Fordson. I got some thing to do when the summer comes as change the front wheel berings (the front tire on the right side wobbles) and paint it up a bit.
Nice FSM As far as the front end wobble, you should jack it up and see what is loose. It may be the spindle and tie rod bushings. If it is the wheel bearings, I would be careful about driving it as it could chew things up and destoy the spindle and hub, and the wheel could come off. I rebuilt the front end in my FPM. The expensive part was getting the correct expandable reamer to do the Job on the big bushings in the front axle. I had a reamer to do the small tierod bushings on the shelf. Dandy Dave!
