hi
does anyone here know if it is the same housing for both the n/p raised (1:1) pto andd the "old" raised pto ( 1:1.333) , will it be able to simply change the gears inside ????
raised pto gears
raised pto gears
Fordson forever
Re: raised pto gears
According to the New Holland website, the part number for the housing changed in June 1963. That makes sense, because when the ratio changed, the gear size changed, so the distance between bearings in the housing would have changed too.
Here you go.
http://agriculture.newholland.com/us/en ... fault.aspx
Scroll down to "New Holland Parts Search" and click on it.
When you get to the search box, put the letters FMD. A list will come up and the tractor list is near the bottom. Dandy Dave!
Thanks for the link to New Holland.
Have tried to get on their site from England; but they want me to register, give business details, tractors owned etc. submitted all this but they never came back with a login.
So thanks again, i'll be on their site tonight, and annoying the man at the parts counter tomorrow.
thanks
great link. I guess there still is'ent any chance of getting a n/p raised pto
, I have no problem finding the old ones , and I even found a later (service model) , with the big shaft and bearing on the end , but still 1:1,33 gear
Fordson forever
