I have a 54 FMD parts tractor with an odd set of solid one piece cast iron, bolt inside rear wheel weights. They are very large and heavy. I would guess at least 500lbs each. This is the only set of these I have ever seen. Are these after market or Fordson issue. Pix coming
Brian,
They are normal Fordson wheel weights, but most people around here put them on the outside. This is the only set I've seen, in person, that were on the inside.
We would fit them on either side depending on the wheel setting and what the customer wanted. On the '000nd series tractors some customers had them on both sides at the same time.
Tom
That's not my tractor, so I don't know much about it. I bought his Power Major and he kept that Major, but I think he sold it later. If he had sold them both at the same time I would have brought my big trailer and took two home.
