am thinking about fitting some double acting spool valves to my 4000 if i port off the auxiliary and return return feed via tapping the filler plug my question is if i put the auxiliary switch in the middle , lift arms and auxiliary would i be able to use both at the same time , wanting to use a reverse-able plough would this be possible? any tips would be great, not too hot on hydraulics
Fit an adapter like this under the plate on the lift, use a spool with power beyond capability. then you can have as many DAR outlets as you want without messing up the tipping pipe. Spools will also function correctly without messing up the 3-point linkage.
frode
1957 County MarkIV Crawler
1964 County Super-4
1967 County 654
1977 County 7600-FOUR
ok when you mean under the plate on the lift does this adaptor go under the auxiliary switch just under the seat ? sorry if i seem a bit dumb don't know much about hydraulics but learning fast!
shergar wrote:ok when you mean under the plate on the lift does this adaptor go under the auxiliary switch just under the seat ? sorry if i seem a bit dumb don't know much about hydraulics but learning fast!
yes, under the plate.
frode
1964 County Super-4
1967 County 654
