I am now the proud owner of a 1970 Ford 3000 and Lambourn cab with under 7000 hours on the clock. However this old girl has been standing for I am told about 25 years following a slight breakdown when No 1 conrod made a break for freedom and put a hole in the block and snapped the camshaft.
Now I have 2 options,
1. Rebuild existing engine including block repair
2. Fit 4600 engine which also requires full rebuild but doesn't have damaged block.
The repair costs I imagine are pretty much the same for both engines with the exception of the block repair but should I retain the originality of the 3000 or go for the power increase with the 4600. I am not planning on the 3000 being expected to too much heavy work as I have the 4610 for that - basically it will be carrying round bales on a rear spike into the field in winter and possibly rolling and topping with a 6ft topper if required at busy times.
To be honest I would go for re building the good block if its not gonna be a show tractor. I have seen guys weld blocks as you describe and get away with it.
The risk of it not working is high. You will have to spend a lot of money on it to re build then if it doesn't work spend option 2 money as well. or can ya maybe find an original 3000 block and sleeve it out if its gone porous in the cylinders this could be a problem that appears re building yours too .
Its kinda a high risk card game I guess, How much do ya want to bet .
Gavin, there is also option 3, go to your local Case/New Holland dealer and see if new short blocks are available.(New block,crankshaft,conrods,pistons,camshaft and gears,oil pump, but without injector pump and water pump.)Might cost more than a rebuild,but at least you know its going to work first time, and most likely the most cost effective in the long run. TSG.
Fordson PETROL Dexta
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
I considered option 3 when I did our 4610 engine last year and ruled it out as too expensive. Having done that engine I know the costs and problems (beside being a mechanic by trade lol). My concern is mostly the damaged block although I feel it is not structural so making it oil tight is the main criteria.
