FM Side Engine Rail
icom102
FM Side Engine Rail
Post by icom102 »
Have discovered a problem with one of the side rails on my major where it bolts onto the gearbox theres only one bolt holding it on the other bolt holes have a lot of corrosion in them and ones broke off see picture can anyone provide any help what if any can be done?
Timeee
Re: FM Side Engine Rail
Post by Timeee »
Dear icom102
Woh, that's not good! There should be 4 bolts, hex head 1/2inch UNC by 1 and 3/8in long at the transmission end securing your rails. If you are lucky, try running a 1/2 inch UNC tap into the transmission mountings to clean them up. If the threads are stripped, you may be able to put in something like a helicoil to restore the threads. Something more extreme may be needed to restore the broken off casting if needed. If you can get 3 bolts in each side (good and secure) and don't have a loader working at maximum capacity on it, you should get away with it. Others may have different opinions. You may have to ease the front ones loose, to get 'em all to line up. Good luck.
Tim
icom102
Post by icom102 »
Cheers can it be welded ?
August
Post by August »
I made the same job for my FSM. I found from local screw dealer a special threaded sleeve. The sleeve has inside thread for bolt and outside works as a thread tap tool. First you have to drill the suitable hole for the "tool", then screw bolt with lock nut into the sleeve and turn it to the predrilled hole. When it goes to the bottom, loose nut and unscrew the bolt. The threaded sleeve tool remains the hole and you have a very good thread for bolt. It's pretty much simplier and cheaper than Helicoil, but I don't know are there this kind of threaded sleeve available in UK.
Fordson Super Major, 1963
Ford Consul, 1960
Major Mike
Post by Major Mike »
Sure it can be welded, for example grind some material off and fit long nuts into hole.
Previous owner had drilled two extra holes
Looks terrible but now threads are ok :lol:
Super Major -62, Super Major 6 Cargo ~130 hp, ford 4550 & Haka, Ford 6600 backhoe, Valtra 6400
icom102
Post by icom102 »
I was told as it was cast it would be very hard to weld
Cast iron is hard to weld. Cast steel can be welded like normal steel. So this can be welded.
icom102
Post by icom102 »
so Cast steel can just be welded normaly i dont need anything special?
That's right.
icom102
Post by icom102 »
