hydraulic parts
jambug123
hydraulic parts
Post by jambug123 »
im going to repair the position control pin on my dexta but the plunger and yoke are siezed solid are they inter changable between a 2000 and the dexta.
regards
James
jambug123
Post by jambug123 »
i took the lift off and found that i have a bent linkage aswell as the position control pin being worn halfway through. the linkage that is bent is the control conecting link with the draft sping on. is it possible to heat this up and bend it back without weakening it?
James
