The lift cover
Open, may be for the first time in 52 years: rust, condensation, dirt
View in the lift housing. On the left is the pump and the filter, I still don't know what the tin on the right is for.
On the left the worn one, on the right a replacement I welded up and grinded round.
You can see the hollow wear on the position controll pin very well in between the two springs when lifting up the whole position control mechanism. I found the cam being very rough. Everything apart from the ram cylinder and the cross shaft needs to be taken out
The filter doesn't need replacing according to the manual. I think I will ignore that advice and replace it anyway.
EDIT: now I know how to include pictures from Picasaweb, I got rid of the link for easier viewing.
