Fordson Major Date
dorothea
Fordson Major Date
Post by dorothea »
My first posting with a query no doubt raised many times previously. I have a Major with serial number stamped on a plate on the firewall: 1447320. Engine has S659895 adjacent the injector pump and L16A is on the casting adjacent the clutch linkage. Any info would be much appreciated.
David.
Re: Fordson Major Date
Welcom to this forum.
You have a september 1957 model MII, but a replacement engine. The casting code is also september 1957.
dorothea
Post by dorothea »
Henk
Thanks very much for your speedy reply - and for the welcome. I hadn't thought it was that old. Not bad considering it's in use most days!
David.
Given the fact that most Majors had a hard life and still are in use, tells you how good these tractors are.
