The Major was very popular for backhoe-use here in Norwaty (County too). On almost every conversion I have seen, the u-channels connecting the front axle to the gearbox is replaced with a subframe extending down and back under the rear axle. This subframe is a part of the backhoe. The tombstone in the front is not used anymore. Front axle is mounted to t.he subframe. Hydraulic pump and tank is mounted in front. This arrangement is also used on the smaller units...
frode
1957 County MarkIV Crawler
1964 County Super-4
1967 County 654
1977 County 7600-FOUR
My plan was to mount it to the frame of the front loader, but with the opportunity to take it of and use the 3p
Have u some pictures of them
Why dont the use the hydraulic from the tractor pump
Fordson for life...
My Back hoe is a Massey. It has a pump mounted in the nose in front of the engine and was installed that way at the factory. From memory, Is not the New Majors pump only around 3 gallons per Minute. The Fordson backhoes I have seen all run off of a similar front mounted pump. If memory serves me right, these are around 8 gal Per minute pumps. Dandy Dave!
could you not make it a pto pump?
or if you mounted it to the front you could link 2 systems together to have a greater LPM and live hydraulics
I like the design looks good but the slew pivot looks a bit light duty compaired with others. have you run stress tests on the model?
Regards,
john.n wrote:could you not make it a pto pump?
Regards,
Like the idea with the front pump, so it can feed power steering and the front lift im planing to make
I havent maked a strees test yet because im not all happy with the design
I have changed the mainframe many time since i posted this first time
i also have changed the main boom to a curved one
Fordson for life...
No, I never run it at full throttle. It is just a listed rating for the pump. Although the RPM gage on the tractor goes to 2,700, 2000 RPM is not out of the question for the 3 cylinder perkins. Dandy Dave!
