My engine number is 1482926.
Which part of the bolt do I measure, head, shank or threaded section.
I got a engine kit off Agriline and fitted the liners by pressing them in so there was no more than a .04 thou protrude so they are nearly flush.
Do I need to remove the liner and refit without the O-ring to ensure they do not sit low?
Do I need to check any other measurements or just install the kit?
