(see red arrow) Is this a common thing or is something wrong.
Hydraulic pump
Hydraulic pump
At the end of the summer the hydraulic pump gave some trouble. Because I have to renew the rear axle seal and remove the rear end cover, I could check it out. When I opened the pump I found the O-ring around the relief valve broken.(see red arrow) This was the same when I rebuild the pump about 7 years ago. Then it was also broken on the exact same place.
Re: Hydraulic pump
No one ever had this problem?
Re: Hydraulic pump
Yes, worn pump. Too much axial clearance, or do you say, end play is too big. You have to grind or sand down the pump body.
hopefully you understand my bad language....
Another way is to do shim plates, behind the bearing cups.
Super Major -62, Super Major 6 Cargo ~130 hp, ford 4550 & Haka, Ford 6600 backhoe, Valtra 6400
Re: Hydraulic pump
Thank you Mike.
You are right I think. The bearing are 0,5 mm lower than the surface. I will make two shims from 0,5 mm.
Re: Hydraulic pump
Thank you Mike.
