Super & New Performance Super gauges - differences
AdrianNPMajor
Post by AdrianNPMajor »
Could somebody explain the differences between the Super Major and New Performance Super Major gauges? I'm interested also in the difference between the Smiths and AC products. Any photos would be great. I know a little about this subject, just enough to be confused! :scratchhead: :D
Best
Adrian :thumbs:
Re: Super & New Performance Super gauges - differences
Post by Dandy Dave »
For the RPM and hour meter, There is a left and right. If memory serves me correctly, the ones that the needle moves from the left is for the supers. This is because of the newer injection pumps and drives. I'm sure others can tell you more and will have photos. Dandy Dave!
peter2
Post by peter2 »
on my January 1963 Super Major the RPM gauge goes anti clockwise (0 is on right side). Actually I have one of this cheap repro parts without light. The first stopped working after 1,2 hours, this one shows RPM but does not count the time. The driving cable comes directly from the injection pump.
My Super is from France (with a french type plate under the bonnet) and had a defect RPM gauge with german text with it. This leads to another question: Is (or was) there a gauge with french text available?
Peter
1963 Super Major
AdrianNPMajor
This is my tacho gauge, u/s at the moment, taken off a September 63 NP Super.
How come Peter's gauge from a Super goes anti-clockwise with the zero on the right, but mine goes anti-clockwise with the zero on the left? :scratchhead:
I was watching this gauge on eBay (see link below). It has the zero on the right and goes clockwise. Confused?! Me too! :D :help:
Another question following up on Peter's - how many different language variations did the gauges come in?
http://www.ebay.co.uk/itm/Fordson-Major ... 7675.l2557
Best
Adrian :thumbs:
Mjg1705
Post by Mjg1705 »
Hi Adrian - that German tacho was mine until I sold it tonight - hence matching eBay name :D - I have several tachos - and they are super - but differant cause the early supers used Simms pump therefore the gauge ran normal - minimec pump ran alternative way - what I find annoying is why some tachos have the "gauge" in the bottom and othes have it on the top - why the two variants of layout ?! :scratchhead: I think we are all confused ! And as language variants go - I think it was only British and German -
liam
Post by liam »
Peters gauge has the numbers on the top half of the clock ,it may be an AC gauge. Liam.
Spicklas
Post by Spicklas »
There are gauges with swedish text too, I have one. I don't know if the swedish one was sold with tractors in Norway or Denmark, but at least it wasn't sold with Finnish tractors.
In a nutshell the ones going anti-clockwise are the ones that have cables going straight to the fuel pump, and those are exclusively minimec-pumps. The repro-gauges have the scale from dexta, so they are incorrect.
Roadless63
Post by Roadless63 »
All super majors with minimec pump had clocks that ran anti-clockwise to suit the drive taken off the back of the pump. The new performance super majors are different because they dont have separate PTO markings for std and raised PTO on the face, just one (since raised PTO on NPM is same ratio as standard PTO unlike earlier majors).
I dont know why there are some clocks going with needle on top and some underneath, presumably due to supplier availability.
AC gages. https://www.google.com/search?q=ac+hour ... 79&bih=744
Smiths gages. https://www.google.com/search?q=smiths+ ... r&tbm=isch
There sure is a Honey Wagon load of them. Dandy Dave!
AdrianNPMajor
Thanks everyone. Very useful info that clarifies the issue.
Best
Adrian :thumbs:
