I have a major leak on a Major p/s unit. It appears to be from the main pulley shaft. Can someone point me in the right direction? Is it a matter of removing the pulley and then the seal or is the job more complicated?
Thanks Peter
Power steering
anthonygos
Re: Power steering
Yes the pulley then snap ring (big one) snap ring (small one) then the bearing, after the bearing you will see the oil seal, the pump shaft may get in the way of you to take out the bearing, its better to remove the pump body.
Don't just leave it in the shed, Fordson's are made to work, so take it out and work it....!
