Hi All,
Did little post searching, but didnt find what I needed. Im in the process of converting to an alternator on my 53 new major, as many have done before. I understand that I have the 1 inch wide belt, and some later models had a narrower belt. The problem I am having is finding a pulley to fit the almost 1 inch wide belt. I have ordered off amazon, only to return because it was made for a 3/4 inch wide belt, not 1 inch. Any ideas or advice on where to find a wider pulley to fit the GM style 10 si Alternator? Any advice is greatly appreciated.
Thanks,
Witty
Alternator Pulley
Re: Alternator Pulley
I believe most people just run the thinner belt.
Pat
Pat
Unfortunately, the other pulleys are 1 inch wide as well. Im going to try a way over priced ebay special that claims to fit a 3/4" belt. if the current belt wont fit down in deep enough, I will try going to a 3/4" belt and see how low it rides in the other pulleys.
Watch out witty73, vee belts drive on the sides and an alternator will put more drag on than a dynamo, if the narrow belt rides at the bottom of the drive and w/pump pulleys it'll wear quickly and slip or break - do you know a local HSM or someone good with a lathe who could turn you up a wider pulley for the alternator ??
What was your Amazon 3/4 inch pulley made of -- caste iron or pressed steel?
If the latter you could increase the gap between the flanges by pressing, or hammering, a steel rod between the flanges to widen the inner width -- not necessarily to the full 25.4 mm. If attempting this be aware that the flanges could break apart unless clamped together at their joint.
Bosch market a belt width of 22.8 mm [type 20A] which, I believe, sits fairly comfortably in the 1inch [25.4mm] crankshaft and w/pump pulleys. As a further check, the 20A belts have a depth of 13mm.
Pavel
Pavel
Hi Witty
Just a thought here as the purists would say your" Buggering up a classic" Putting an alternator on
, But it don't really bother me as for a working tractor it's better and your still saving a classic
. Have you looked into changing the other pulleys to run narrow belt with used ones from a wreckers. I think all pulleys fit the crank but the front seal inside Diameter might of changed ( needs confirming one way or the other) and you would have to re mark the timing notch on the pulley outer edge, but that shouldn't be to hard
Just kinda thinking that may be the quickest easiest way to go, instead of a nearly half right fix.
Most places stock the narrow belts so replacement might be quicker than gettin funny looks at the auto store, trying to get a wide one the right size at 4 on Sat afternoon when you need the tractor
. Then waiting for someone to get it in stock as they don't carry them
