I am seriously considering buying a Power Major to replace a Massey MF30 (French built) which I use on our hobby farm here in Chidlow, Western Australia.
I viewed the Fordson 2 days ago and found it started and ran extremely well, with very little smoke and was relatively quiet until I tried to move it. Pushing in the clutch was fine but as soon as it moved off, it produced a gravelly, grinding sound. Best example I can give is a load of gravel in a large cement mixer. It was definitely worse on the uphill drive and considerably quieter on the downhill run. The owner told me that 'it had done it since he'd bought it', 6 months previously. It moved freely enough but due to fairly limited space, I only got it into 2nd and it made the same kind of noise in this gear also.
It was good in all other ways aside from being very heavy on the steering which I put down to the large FEL which it had fitted. The owner said that he was selling it because it wouldn't easily get around his 10 acres of olive trees as they were fairly close together. He'd already purchased a small Fiat tractor for this purpose.
I'd sincerely like to get some suggestions as to the potential seriousness of the noise. Happy to reply ASAP to any comments or questions regarding the matter. Also, if anyone has any suggestions as to how I can further test and narrow down the problem during another test drive, I'll be happy to drive the 60kms to try it out. Needless to say, I probably need to be quick as it may be sold in the meantime.
Many thanks,
